load sharing and load balance
Ibrahim Jamil
Level 6
Level 6
Hi Netpro
what is the difference between load sharing and load balance in terms of Cisco router speaking a protocol language
thanks
cadet alain
load balancing: are you gonna use multiple paths to forward packets to same destination network
load sharing: what is the ratio of the load balancing, for equal cost this is 1:1 and for EIGRP unequal cost it is the ratio of the metrics.
Regards.
Alain
milan.kulik
Level 10
Level 10
different documents/books are using both terms for the same: multiple paths to the destination used at the same time.
BR,
Milan
