Load sharing FR connection with ADSL connection
john.vossikas
Dear All ,
i have 2611XM with the following conf.
service timestamps debug uptime
service timestamps log uptime
hostname ess-cy
boot-start-marker
boot system flash:c2600-ik8o3s-mz.123-3.bin
boot-end-marker
logging buffered 52000 debugging
clock timezone Europe/Athens 2
clock summer-time Europe/Athens date Mar 30 2003 3:00 Oct 26 2003 4:00
no aaa new-model
ip subnet-zero
ip cef
ip domain name ddddddddd
ip name-server 194.154.128.2
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
no voice hpi capture buffer
no voice hpi capture destination
interface FastEthernet0/0
description $ETH-WAN$Connection to ADSL
ip address dhcp client-id FastEthernet0/0
no ip redirects
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Serial0/0
bandwidth 512
no ip address
encapsulation frame-relay IETF
ip route-cache policy
frame-relay lmi-type q933a
interface Serial0/0.1 point-to-point
description Connection To Spidernet
bandwidth 512
ip address 194.154.134.150 255.255.255.252
no ip redirects
no ip proxy-arp
no cdp enable
frame-relay interface-dlci 20 IETF
interface FastEthernet0/1
description $ETH-LAN$Connection To Firebox
ip address 194.154.134.161 255.255.255.248
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
ip nat pool Cytanet 212.31.103.51 212.31.103.54 netmask 255.255.255.248
ip nat inside source list 1 pool Cytanet
ip http server
ip http authentication local
ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 194.154.134.149
ip route 0.0.0.0 0.0.0.0 212.31.103.49
access-list 1 permit 194.154.134.160 0.0.0.7
dial-peer cor custom
banner login ^CXXXXXXXXXXXXXXXXXXX^C
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
The problem that i have is that on the fastethernet 0/1 i have a firewal which is doing the nat.
With these equal routes i do have connection to the internet but very slow .
What should i do for load balancing the two connections?
Thanks!
since you have CEF enabled, per-destination load-sharing is enabled (which is the default when configuring CEF). Depending on your destinations, traffic might be routed over the (slower, I would assume) frame relay link.
I am wondering if effective load sharing is possible in your situation, since you have a firewall that is doing NAT. What is connected to the other end of the frame relay connection ? Part of your internal network ? Can you try and route traffic for the specific networks (if they exist) at the other end of the frame relay connection out interface Serial0/0.1, and point all other traffic to the firewall, that is, leave the default route pointing to 212.31.103.49 as is ?
GP
