Load Sharing--- Internet
Anukalp S
Hello..
I have a internet router connecting two internet circuit provided by same ISP, BGP is running on this router, i am looking for load sharing/load balancing over both links. Could you pls help how this could achieve.
15 Replies 15
Hi Hiraman,
NAT could be done on the router but in the case described by the original poster, NAT is done on an ASA device right behing the Internet facing router. The Internet facing router only does routing. It would be possible though to move NAT from the ASA to the router if needed.
