load-sharing via EIGRP across multiple routes in DMVPN
iskoy.istem
is it advisable to have a load-sharing across multiple path on dmvpn or fail-over would be more suitable? as i have looked at, it will introduce possible asymmetric routing and may have problem in the future if i want to run zone-based firewalling on the hub router? please give you expert advice on this.
SOcchiogrosso
Level 4
Level 4
What is going to be the circuit technology the DMVPN is going to be running over?
I've seen situations where the primary link was Ethernet and the secondary link was a bonded T -multilink - in that case the traffic that was load shared over the multilink experienced a considerable delay over the traffic that was sent over the Ethernet link, in that situation failover was appropriate and not load sharing, your situation may vary.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
