Loadsharing per packet on ISR Routers?
blue-networks
is loadsharing per packet supported on the ISR routers?
What commands can I use to influence Loadsharing on the ISR routers?
Thanks and best regards,
Peer
Edison Ortiz
Yes,
It's supported on ISR routers, please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1012465
HTH,
__
Edison.
Please rate helpful posts
Edison Ortiz
Yes,
HTH,
__
Edison.
