Local Preference attribute is not propagated to iBGP neighbor
Rinam Shah
As per the below topology, I increased local preference from R9 toward R6 for outbound traffic. But it is not reflected on R6.
Below is the output for R9 and R6:
R9#sh run | s route-map LP
neighbor 192.168.1.2 route-map LP in
route-map LP permit 10
set local-preference 500
route-map LP permit 20
R9#sh ip bgp
BGP table version is 9, local router ID is 9.9.9.9
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 9.9.9.9/32 0.0.0.0 0 32768 i
*>i10.10.10.10/32 17.0.0.1 0 100 0 4755 200 i
*>i16.0.0.0/30 192.168.1.2 0 500 0 i
*>i17.0.0.0/30 192.168.1.3 0 100 0 i
*>i28.0.0.0/30 17.0.0.1 0 100 0 4755 200 i
*>i38.0.0.0/30 17.0.0.1 0 100 0 4755 200 i
*>i172.31.1.0/30 17.0.0.1 0 100 0 4755 200 i
*> 192.168.1.0/29 0.0.0.0 0 32768 i
R9:
R6#sh ip bgp
BGP table version is 24, local router ID is 6.6.6.6
*>i9.9.9.9/32 192.168.1.1 0 100 0 i
* 10.10.10.10/32 16.0.0.1 0 4755 200 i
*>i 17.0.0.1 0 100 200 4755 200 i
*> 16.0.0.0/30 0.0.0.0 0 32768 i
*>i17.0.0.0/30 192.168.1.3 0 100 200 i
* 28.0.0.0/30 16.0.0.1 0 4755 200 i
* 38.0.0.0/30 16.0.0.1 0 4755 200 i
* 172.31.1.0/30 16.0.0.1 0 4755 200 i
r>i192.168.1.0/29 192.168.1.1 0 100 0 i
R6#sh ip bgp neigh 192.168.1.1 received-routes
Total number of prefixes 2
Giuseppe Larosa
Hello @Rinam Shah ,
what you see is normal because R6 is actually the neighbor for whom you rise the local preference on R9.
on R9 it works:
Now the route 16.0.0.0/30 is injected into BGP on R6, as a result of this the locally injected route has weight 32,768
On the other hand R9 will not send back the advertisement to R6 as it has learned the prefix from it, however even if R9 would do it, R6 would still prefer the locally injected route as Cisco weight is a criteria considered first then local preference in the BGP best path selection.
Hope to help
Giuseppe
Richard Burts
Could you post the output on R6, R7, and R9 of the command show ip bgp neighbor
Rick
Giuseppe Larosa
Hello @Rinam Shah ,
on R9 it works:
Hope to help
Giuseppe
Thanks Giuseppe.
