Locating the start configuration file in CISCO 7200 series router
aprasad11
hi Guys,
Would any one know where is my startup config  file located in my router.
CONFIG_FILE  says does not exist but it does boot up with all configs.
BOOT variable = disk2:c7200p-adventerprisek9-mz.124-4.XD7.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c7200p-kboot-mz.124-4.XD8.bin
WARM_REBOOT variable = FALSE
johnlloyd_13
Level 9
Level 9
hi,
could you try issue a dir nvram: command?
7200#dir nvram:
Directory of nvram:/
 1995  -rw-       48292                    <no date>  startup-config
 1996  ----        3669                    <no date>  private-config
 1997  -rw-       48292                    <no date>  underlying-config
    1  ----          46                    <no date>  persistent-data
    2  ----           4                    <no date>  rf_cold_starts
    3  -rw-        3708                    <no date>  ifIndex-table
2095096 bytes total (2036939 bytes free)
johnlloyd_13
Level 9
Level 9
hi,
7200#dir nvram:
Thanks mate this was correct
Original poster says that John's suggestion was correct. So +5
Rick
Rick
