Lock & Key ACL
Rupesh Kashyap
Hi, I have resource on router R4. I have to implement a policy stating that before using any resource on R4, you have to authenticate on R1 with username CISCO. My question is, I have two option for autocommand e.g.Vty line & Username. Which one I have to follow--
Router(config-line)# autocommand access-enable [host] [timeout minutes]
or
Router(config)# Username CISCO autocommand access-enable [host] [timeout minutes]
Giuseppe Larosa
Hello Rupesh,
when I tested this on C3725 with 12.3T the command effective was the first under line vty.
I didn't like my test results: I had the impression there were troubles with AAA new model on the device.
I was not able to get access to the router after the lock and key triggered.
It was a lab and I could easily recover with a power cycle.
About the options documentation of 12.3 says:
The autocommand Command
Use the following guidelines for configuring the autocommand command:
• If you use a TACACS+ server to authenticate the user, you should configure the autocommand
command on the TACACS+ server as a per-user autocommand. If you use local authentication, use
the autocommand command on the line.
• Configure all virtual terminal (VTY) ports with the same autocommand command. Omitting an
autocommand command on a VTY port allows a random host to gain EXEC mode access to the
router and does not create a temporary access list entry in the dynamic access list
I tried local authentication with authentication on the line but using aaa new-model.
Hope to help
Giuseppe
Where we have to give Autocommand access-enable---On vty or on Username if using local authenticatio.
Hello Rupesh,
I did so
Hope to help
Giuseppe
