Log of Login
Mero Cisco
I have configured the easy vpn server and I can connect to this with vpn client dialer. I have configured local AAA at router. Now, I want to maintain the log of the successful and unsuccessful login. I want to log the details of from which ip the vpn request came, which date and time, which ip does the client got and when did he disconnected.
Mero
blau grana
Level 7
Level 7
Hello Mero,
This might help you:
https://supportforums.cisco.com/thread/2011004
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
johnlloyd_13
Level 9
Level 9
Configure in global config:
crypto logging session
crypto logging ezvpn
