05-31-2005 03:46 AM - edited 03-03-2019 09:42 AM
I have 1721 router with 12.2 IOS.
Mrtg from the ISP shows high download during the weekends
I would like to know which machines from the lan, which portocol and which port etc.. is doin.
I would like to track and stop.
What are my options. I have tried IP ACCOUNTING without much luck
regds
Ramesh
05-31-2005 04:23 AM
Do you have your LAN switch monitored by MTRG?
If so you could check the ports on this to see if
any particular host is at high utilization over the
weekend.
05-31-2005 08:07 PM
I do have l3 and l2 switch's, will try that option.
But as my setup has 10 to 12 switch of variant make. I felt it would be tidous and cumbersome to do that.
Wont it be easier to monitor the router where all the traffic are bound to.
regds
Ramp
06-09-2005 04:43 PM
Use NetFlow to get the IP-information (including tcp/udp ports etc.)
Export into a linux-machine (f.ex) and use the following tools:
06-10-2005 01:04 AM
You can use "ip nbar protocol-discovery" in the interface it will all your requirment.
