Login on-failure not working
scain2
Have issued login on-failure log and login on success log commands, however only the on-success works and puts output into log, the on-failure command does nothing.
If I issue the additional command login block-for this causes the on-failure to work, but fills up log with null attempts every few seconds and filling the log.
Any ideas on how to get on-failure to work without the login block-for command
Amit Aneja
Level 3
Level 3
What's the hardware & IOS?
Guess, here is the bug that you may be hitting
CSCsc72647
