Looking for something that can do this...
eilan.barak
So I have a client with 5 external IP's and a private network.
I am looking for a device that will allow me to combine these 2 together in the same network, so for example, there is a web server, it is using an external network, but is behind the same device as the private network.
d-fillmore
Level 2
Level 2
Do you mean you have 5 public IP addresses and you want to host a web server on a private network but be able to access if from the the internet?
The server will be an external address.
I want to have a web server, E-mail and another few.
I want to be able to intergrate this with a private ip network.
ryates_presido
Yo can do this with an Asa or router you will just have to configure static nat for the outside in.
Sent from Cisco
HI there,
it seems you are talking about a DMZ. I would use an ASA (as presido suggested) or if you can't afford it i would upgrade my IOS to a seck9 capabilities and i would create "zones" with CBAC. Can't you draw down a topology?
Alessio
