Loopbacks for Mgmt of devices?
CiscoBrownBelt
Level 6
Level 6
Would it be a better to use loopback interfaces to reach devices for management or use for management traffic of devices?
6 Replies 6
Jon Marshall
Or use ?
Jon
Hi CiscoBlueBelt,
Yes, it will be good to use loopback interface for management.
But I would recommend using Control Plane Policing(CPP) feature along with loopback.
Spooster IT Services Team
Okay.
I configured loopbacks on a switch that connects directly to a router. All SVIs on the switch and sub-interfaces on the router are pingable, except for my loopbacks. Happen to know what I am missing to make the loopbacks reachable?
Have you defined the route at the router for this loopback IP towards switch? and the switch must have the router as a default-gateway.
Is your switch L2 or L3? If L2, unsure you can easily reach the loopback, unless perhaps route to that loopback using a SVI as a next hop (and as noted by Spooster, you'll need a default-gateway defined on the switch). If L3, you add the loopback to your routing topology.
Joseph W. Doherty
If the device is L3, and you have multiple L3 interfaces on it, then a routable loopback on is often a good practice.
