Looped Interface Issue- please help!!!
echo-224.0.0.5
I have a lab environment with 3 routers back to back but one which should be taking the clock (DTE) is up/looped. I have no loop back interfaces on this router and can't understand why this router is reporting back as looped. Can anyone help?  I have provided the sh ver info along with interface statuses concerned.
Thanks.
R3-Paris(config-if)#do sh ver
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version 12.4(15)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 01-Dec-08 14:23 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
R3-Paris uptime is 1 hour, 11 minutes
System image file is "flash:c2600-advsecurityk9-mz.124-15.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2610XM (MPC860P) processor (revision 3.1) with 127422K/3650K bytes of memory.
Processor board ID FOC08360GQ3
M860 processor: part number 5, mask 2
1 FastEthernet interface
1 Serial interface
8 Low-speed serial(sync/async) interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
R3-Paris#sh int s1/0
Serial1/0 is up, line protocol is up (looped)
  Hardware is CD2430 in sync mode
  Description: Link to R1-NY
  Internet address is 192.168.3.2/30
  MTU 1500 bytes, BW 128 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:03, output 00:00:03, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/32 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 96 kilobits/sec
     1150 packets input, 75700 bytes, 0 no buffer
     Received 405 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1152 packets output, 75788 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     3 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
R3-Paris#sh int s1/1
Serial1/1 is up, line protocol is up (looped)
  Description: Link to R2-chicago
  Internet address is 192.168.2.2/30
  Last input 00:00:06, output 00:00:06, output hang 00:47:37
     Conversations  0/2/32 (active/max active/max total)
     335 packets input, 23290 bytes, 0 no buffer
     Received 335 broadcasts, 0 runts, 0 giants, 0 throttles
     398 packets output, 25107 bytes, 0 underruns
     0 output errors, 0 collisions, 64 interface resets
     1 unknown protocol drops
R3-Paris#
stevjarbeck
Make sure encapsulation and clock speeds match on both ends.
The clocks have been checked again to ensure R3 is DTE. Please see below the controller details and the encapsulation types on each. I tried another serial interface which worked quite alright I now suspect if it's the NM-8A/S card that's problematic. If you can think of anything else please let me.
R3-Paris#sh controller s1/0 | i DTE
idb 0x83BB12AC, buffer size 1524, V.35 DTE cable
R3-Paris#sh int s1/0 | i Encap
R3-Paris#sh controller s1/1 | i DTE
idb 0x83BB5F14, buffer size 1524, V.35 DTE cable
R3-Paris#
R3-Paris#sh int s1/1 | i Encap
R3-Paris#
R2-chicago#sh controllers s1/1 | i DCE
idb 0x83B69254, buffer size 1524, V.35 DCE cable, clockrate 56000
R2-chicago#
R2-chicago#sh int s1/1 | i Encap
R2-chicago#
R1-NY#sh int s1/1 | i Encap
R1-NY#sh controller s1/1 | i DCE
idb 0x83AEC4D4, buffer size 1524, V.35 DCE cable, clockrate 56000
