Looping issue and Eigrp neighbor Ship is frequently going Down
Hi Friends,
PFA of Sh run output , network diagram , router logs and wire-shark output.
In this typologies getting the loops between R1 , R2 and R3  routers, is there any way to avoid those loops in this topology.
and also we are observing the EIGRP neighbor  is restated frequently.
created one route-map in R1 for split the traffic , so that one host 10.10.10.31 (PC3) Should take the path vai R3 wen it is communication PC2 and PC1 should reach the PC2 vai R2.
Requesting you to go through the all configuration and suggest me what would the best solution for this.
deb
Philip D'Ath
What model routers are these and what software versions are they running?
