%% Low On memory
mvnaveenforever
Cisco 2600 router getting hang with the message displayed on console %% low on Memory.Can not login to the router.Once the router is reloaded it comes up.Running with deferred release.
Giuseppe Larosa
Hello Nav,
there is one or more processes that doesn't release memory
try to use
sh proc mem | inc Free
to monitor the amount of total Free memory over time.
Verify if there is any feature you can remove from the router.
Hope to help
Giuseppe
Nav
The symptoms sound like there is a memory leak (and the mention that you are running a deferred release supports that assumption). So in addition to the suggestions from Guiseppe I would suggest that you upgrade the software on the router to a more recent version, in which hopefully the memory leak is fixed.
Rick
Rick
