Low throughput VPN tunnels.
Jpadams23
We have multiple sites that have either fiber 20mb d/u or cable 50/10 d/u. Recently we have upgraded our head end router to a 2921 security based router and noticed that no matter if we are sending or receiving the most we can push is 1.6Mb. I would expect this number to be at least 8Mb for uploading and at least 18mb for downloading from other sites.
I have included parts of my config and screen shots of bandwidth usage to help with the troubleshooting.
Head End - 2921
(config)
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
lifetime 1440
crypto isakmp key secret address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10
crypto ipsec transform-set ERS-AES-SHA esp-aes 256 esp-sha-hmac
interface Tunnel0
bandwidth 10000
bandwidth receive 50000
ip address 172.16.1.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication ERS2Way
ip nhrp map multicast dynamic
ip nhrp network-id 990
ip nhrp holdtime 360
ip tcp adjust-mss 1360
delay 1000
cdp enable
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 4515
tunnel protection ipsec profile ersvpn
router eigrp 100
network 172.16.0.0
redistribute static
Remote End - 2811
(config)
encr aes 256
group 2
lifetime 1440
crypto isakmp key secret address 1.1.1.1
crypto ipsec profile ersvpn
set transform-set ERS-AES-SHA
interface Tunnel0
bandwidth 20000
bandwidth receive 20000
ip address 172.16.1.4 255.255.255.0
ip mtu 1400
ip nhrp map 172.16.1.1
ip nhrp nhs 172.16.1.1
no ip mroute-cache
delay 1000
qos pre-classify
cdp enable
tunnel source FastEthernet0/0
tunnel destination 1.1.1.1
tunnel key 4515
router eigrp 100
network 172.16.0.0
network 192.168.34.0
auto-summary
caplinktech
John,
You are most likely running into an issue with the remote router process switching the VPN tunnel packets.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
The 2811 is only capable of 1.6 Mbps of throughput for process switched packets which matches the throughput you are getting.
Is there a way to use ip cef instead of process switching on the routers?
All of my remote offices are 2811 and my tower locations 881.
I guess I should verify stuff before I post.
I did a show ip cef and it shows all of my tunnel addresses. I then ran a sh cef int tun 0 and it shows the following.
  Corresponding hwidb fast_if_number 8
  Corresponding hwidb firstsw->if_number 8
  Internet address is 172.16.1.4/24
  ICMP redirects are always sent
  Per packet load-sharing is disabled
  IP unicast RPF check is disabled
  Inbound access list is not set
  Outbound access list is not set
  Interface is marked as point to point interface
  Interface is marked as tunnel interface
  Hardware idb is Tunnel0
  Fast switching type 14, interface type 0
  IP CEF switching enabled
  IP CEF Feature Fast switching turbo vector
  Input fast flags 0x2000000, Input fast flags2 0x0, Output fast flags 0x208000, Output fast flags2 0x0
  ifindex 5(5)
  Slot -1 Slot unit -1 Unit 0 VC -1
  Transmit limit accumulator 0x0 (0x0)
  IP MTU 1400
  Real output interface is FastEthernet0/0
So how would I disable the process switching so it will run on cef only.
