MAC address filtering on a 2821 router
emildatcu
On a Cisco 2821 router, my customer wants to retsrict access to "enable" mode both by using a user name/password combination and a list of approved MAC addresses.
Any ideas?
Emil
royalblues
Level 10
Level 10
You can configure local usernames on the device and chnage the login authentication for the VTY lines to Local
username admin privelege 15 secret
line vty 0 15
login local
I dont think you can restrict the telnet login to particular mac-addresses as vty does not allow you to apply a MAC-access list. you can however apply an access-list that restricts only certain IP address to do telnet.
access-list 1 permit host
line vty 0 15
access-class 1 in
Narayan
Narayan, thank you very much for your response. I might have not been clear enough, but I don't have a problem setting up users and access lists based on IP addresses.
My problem is related to the fact that my customer wants user logins to be restricted to a certain list of MAC addresses.
Best regards,
Emil
