MacSec configuration on ISR1109
robert.melzer
Dear Ladies and Gents,
does ISR1109 support MacSec?
The command mka ? on interface level show "unrecognized command"
On my router is IOS-XE, 16.09.06 with ipbase installed
If it does with which Version?
Best Regards
Robert
balaji.bandi
Dear Balaji,
I thought that securityk9 is still enough. Should I have to use hseck9?
Please give me a hint.
Robert
yes it covers - Regular crypto RTU license
BB
Dear Balaji,
thanks for your reply. As for my understanding I have to active hseck9?
As output show license of the ISR1109
Thanks for your support.
Cisco IOS XE Software, Version 16.09.06
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 27-Aug-20 01:47 by mcpre
System image file is "flash:c1100-universalk9_ias.16.09.06.SPA.bin"
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
Smart Licensing Status: Smart Licensing is DISABLED
Best Regards
Robert
