Mails to a particular domain not delivered if size is above 1 Mb
jaggi1234
Problem Statement : Mails to a particular domain 'B' not delivered if size is above 1 Mb. However the target domain 'B' receives mails from other domain without any problems
Our Network : Comprises of a sinlge 1700 Cisco Router. The network traffic includes SSL VPN tunnel also besides the regular FTP, http, SMTP.
Explanation : We noticed that mails to a particular domain 'B' was not getting delivered. On close scrutiny, we found that the window size was reducing as the mail was getting delivered. In all probability, this was attributed to a rougue router which was in the mail path.
MTU for our router happens to be about 1472, while the same is 1412 for the target domain 'B'.
Further, there were no rules in the content filtering tools at either end that was blocking the mail
One of the research led to a link http://www.postfix.org/faq.html. (Mail fails consistently with timeout or lost connection) This points to "ICMP MUST FRAGMENT" to be set on the router.
My quesiton is how do we trace this rouge router to enable the setting ?
Response much appreciated.
Thanks in advance.
Jagdish
8 Replies 8
Eugene Khabarov
Level 7
Level 7
Try to use ip tcp adjust-mss on
you inside interface to fix you issue.
For example, try ip tcp adjust-mss 1300.
also look here: http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
Please rate if this helps,
Eugene.
Tried the tcp adjust-mss on the router with value 1300. I have tried from my side. Did not work. The problem still remains. Should the same be done on the target side also ?
Please, post your config here.
Here is the configuratiuon :
Current configuration : 910 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname accord
ip subnet-zero
ip name-server 164.164.4.5
ip name-server 164.164.128.16
isdn switch-type basic-net3
interface BRI0
ip address negotiated
encapsulation ppp
shutdown
dialer-group 1
ppp authentication pap chap callin
interface FastEthernet0
description link to local LAN
ip address 164.164.96.177 255.255.255.240
speed auto
interface Serial0
ip address 164.164.100.54 255.255.255.252
interface Dialer1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 164.164.100.53
no ip http server
snmp-server community public RO
snmp-server community private RW
line con 0
line aux 0
line vty 0 4
  login
end
_____________________
Hope this helps...
So this had no effect?
int F0
end
try to use tracertoute and ping each hop with maximum allowed mtu and df bit set.
Tracert results :
tracert 164.164.96.1
Tracing route to 164.164.96.1 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  kaveri.appsoft.accord.com [192.168.1.240]
  2     1 ms     1 ms     1 ms  164.164.96.177
  3    99 ms   104 ms   167 ms  164.164.100.53
  4   137 ms    67 ms    39 ms  164.164.96.1
Trace complete.
______________________
Ping Results :
ping -l 1472 -f 164.164.96.177
Pinging 164.164.96.177 with 1472 bytes of data:
Reply from 164.164.96.177: bytes=1472 time=2ms TTL=254
Ping statistics for 164.164.96.177:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 2ms, Maximum = 2ms, Average = 2ms
ping -l 1472 -f 164.164.100.53
Pinging 164.164.100.53 with 1472 bytes of data:
Reply from 164.164.100.53: bytes=1472 time=60ms TTL=253
Reply from 164.164.100.53: bytes=1472 time=30ms TTL=253
Reply from 164.164.100.53: bytes=1472 time=25ms TTL=253
Ping statistics for 164.164.100.53:
    Minimum = 25ms, Maximum = 60ms, Average = 35ms
Pinging 164.164.96.1 with 1472 bytes of data:
Reply from 164.164.96.1: bytes=1472 time=247ms TTL=252
Reply from 164.164.96.1: bytes=1472 time=223ms TTL=252
Reply from 164.164.96.1: bytes=1472 time=277ms TTL=252
Ping statistics for 164.164.96.1:
    Minimum = 223ms, Maximum = 277ms, Average = 242ms
ping -l 1500 -f 164.164.96.
Pinging 164.164.96.1 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Any updates on this ?
Any updates on this ....?
Thanks in advance.
Jagdish
