Main office connect to Branch on outdoor Wireless
samuel_M9
Hello Experts
I have been told to connect our branch offices over outdoor point-to-point wireless CPE. The wireless brand is Orthogon. The Main office got cisco 4507 L3 switch where all building switches terminate. DHCP,DNS and all application are hosted in main office.  The branch office got ONE 24 port POE Switch cisco 2960 where all users will be connected, On Port 0/24 of 2960 switch at branch will terminate the outdoor Wireless and other end will be terminated on 4/15 of 4507 at main office
Can you help what command I need at both interface where Wireless is terminated.
when we connect floor switches to 4507 we got these commands on access switches
vtp mode client
vtp version 2
vtp password cisco1
vtp domain LIC
Fiber termination port configuration - switchport mode trunk
Appreciate some quick help
Thanks to all in advance
Samuel
Leo Laohoo
I'm not familiar with the point-to-point wireless you are using.  But, in my opinion, whether or not you are running one or more VLAN configure the ports conntected to the WAP as dot1q trunking.  To make it smoother, configure the allowed VLANs.
I also hope that the WAPs you are using will also support 802.1q trunking.
Hello
if I understand you correctly then you mean to configure
on the interface of swtich connected to outdoor Wireless unit
Samuel
That's correct.
If you are running multiple VLANs make sure your WAP supports this feature too.
