MAN WMPLS
morph.andy
Wanted to gauge peoples opinions on a WAN setup - there's currently 5 sites which use VTI tunnels
between each other and BGP neighbours in a full mesh (it is EBGP). Path selection is done via weight, its all Cisco kit. MPLS is being introduced but only at 3 sites - these 3 sites will use MPLS as primary to
sites with MPLS and then VTI (with BGP) as a backup. The other 2 sites will always use VTI (as nothing
else).
I can appreciate that with MPLS you'd normally use local prefer to decide routing, scalability being
a big part of it. But with us having such a small setup (which will potentially get smaller - 100% not bigger) I'm wondering if its such an issue using weight?
Quite new to this so would be interested to hear peoples opinions
Weight is in router only and can not be advertised so using it between many routers is not good idea.
LP is use only between ibgp not ebgp peers
AS-path is use between ebgp peers
6 Replies 6
balaji.bandi
Depends on what Link speeds and stability, if the Link is good and bigger pipe than VPN, then i prefer MPLS as preferred path.
you can also setup if bad quality of path you can use alternative to VPN (based on the monitoring)
i will start with 1 site to use MPLS and monitor, Gradually add 2 more is better option my point of view. (rather if MPLS bad, all 3 site will be affected with performance).
BB
I was thinking more or the advantage / disadvantage of using weight over local pref
My views as below :
  • Choose weight for simple, local traffic steering decisions on a single, Cisco-based device. It provides quick, unilateral control without affecting other BGP speakers in your AS.
  • Choose local preference for standardized, scalable, and consistent traffic engineering across your entire network. It requires more planning but ensures all routers within the AS follow the same polic
My Notes :
BB
Thank you, if scalability is the only disadvantage I think we are ok, we can deal with the admin overhead
Joseph W. Doherty
Don't know is Cisco still provides PfR as a stand alone option, but it's "magical" with WAN performance when there are multiple paths
