PRTG MONITOR 9320 stacked switch
deep-dive
we have 3 cisco 9320 switches in stacked state. Now prtg only monitoring switch PS status which is in master. We need to monitor 3 switches PS status. There no separate management Ip. Can anyone help here
5 Replies 5
So you see only master PS Info other not seen?
MHM
yes
hi @deep-dive, you can use SNMP monitoring for this requirement.
Good luck
KB
already using snmp
Hello @deep-dive,
Can you please check this : https://community.cisco.com/t5/network-management/use-snmp-to-monitor-the-power-supply-status-of-stacked-switches/td-p/312562
It is not same model but you can find solution )
Thanks !
