Manipulating OSPF metric calculations
srosenthal
Level 4
Level 4
How do I configure the OSPF process to reflect the following metric calculations?
Bandwidth (Mbps)     OSPF Cost
10000                              2
10                              2000
1.544                         12953
0.768                         26041
Thanx, Seth
Robert Taylor
You can apply the cost value directly to the interface.  Cost is calculated on a hop by hop basis, and is generally additive, and you can't configure the cost-to-bandwidth numbers on a global basis ... must be done per interface.
int x/x
ip ospf cost x
Rob
Actually I think I figured it out.
If you use the "auto-cost referenced-bandwidth 200" command, this sets the global metric calculations.
Thanx, Seth
Ahh ... very nice ... my mistake.
