Many-to-One NAT configuration
Daniel Anderson
Trying to configure a many-to-one NAT on a Cisco 3845 router running 12.4-7 IOS. I've configured:
ip nat pool Temp 10.11.12.13 10.11.12.13 netmask 255.255.255.255
ip nat inside source list 20 pool Temp overload
access-list 20 remark NAT Traffic
access-list 20 permit 10.10.0.0 0.0.255.255
access-list 20 permit 10.20.0.0 0.0.255.255
With the above configuration I'm trying to get all traffic from 10.10.0.0/16 & 10.20.0.0/16 NAT'd to 10.11.12.13. My only concern is whilst configuring the MAT pool, when I specify the /32 netmask, I receive an error specifying the netmask is too large. Should I be using a different netmask, even though I've specified the start and end addresses as the same?
I've not yet had time to build the above configuration in the lab, would some NAT experts be able to share their knowledge?
10 Replies 10
mahmoodmkl
Level 7
Level 7
HI
U need to enter the correct mask which is given to u.
And have u configured the proper nat statments under the interfaces ie ip nat inside and ip nat outside.
Mahmood
rajeshk200_2
Hi ,
if it only one ip address has to be used for translation ..then u can configure withput nat pool command
ip nat inside source list 20 10.11.12.13 overload
Rajesh
Thanks for the responses
'ip nat inside source list 20 10.11.12.13 overload' is not configurable as a command, after entering source list 20, I can only configure interface or pool afterwards.
With regard to the netmask configured on the pool command, I've currently configured with a /32 which kicks up an error, should I be using /8 or /24 ?
Try /31
rtaulton
you cannot configure a 32 bit mask. Use a smaller mask and you will be okay. It will not affect your NAT.
senthilmds
be specific with your nat ouside interface wheather it is one or two interface. has your inside interface is class B /16. use the below command
ip nat pool test 10.11.12.13 10.11.12.13 netmask 255.255.0.0
leonard.kasneci
try the following config:
interface loopback 1
ip address 10.11.12.13 255.255.255.255
ip nat outside
ip nat inside source list 20 interface loopback 1 overload
Leonard
rawatmohinder
Hi Daniel...
If you want to use two Public Ip Address,then command will be like this...
ip nat pool Temp 10.11.12.13 10.11.12.14 netmask 255.255.0.0
Second if you want to go with single public Ip address..
Then command are....
ip nat inside source list 1 s1 overload
Give your public ip on serial 1 interface..
Hope it helps..
Rate the post if find it useful...
Mahi
The commands to NAT to one IP is not so clear. could you please share the commands again .
Hello
If you wish to use a nat to a single host pool then you need to specify the correct subnet mask that public ip residesin which wont obviously be a /32 address as it will be connected to your next-hop device.
10.11.12.13 10.11.12.13 netmask 255.255.x.x
ip nat inside source list 10 pool Temp
The other alternative is to specify the the interface instead of a pool.
ip nat inside source list 20 interface x/x
Kind Regards
Paul
