Marking Traffic on Cisco 3020 switch
I want to mark traffic on Cisco 3020 switch entering to interface gigabitEthernet 0/1 ingress direction with DSCP values.
interface gigabitEthernet 0/1 is in access mode and in vlan 10.
This is my config:
access-list 1 permit host 10.10.1.1
class-map match-all ipclass1
match access-group 1
policy-map MARK
class ipclass1
  set ip dscp cs4         (or tried ->  set dscp cs4)
service-policy input MARK
I have also enabled QoS globally with mls qos command.
However, when I checked with
show policy-map interface gigabitEthernet 0/1
it showed
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 1
      QoS Set
        dscp cs4
          Packets marked 0
What is wrong or what is omitted?
marksanc
Hi Haru,
Try using "show mls qos interface X statistics".
Thank you,
Mark Sanchez
marksanc
Hi Haru,
Thank you,
Mark Sanchez
Thanks Mark
"show mls qos interface X statistics"  command is working and packets are marked!!!
After your suggestion I found this note in Cisco 3020 docs:
Note Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
