max-reserved-bandwidth ignored when shaping??
Keith Rance
We have a bandwidth management policy to prioritise traffic types across Sat links as follows:
class-map match-all VOIP
match access-groupname VOIP
class-map match-all MAIL
match access-groupname MAIL
class-map match-all VTC
match access-groupname VTC
class-map match-all FILESHARE
match access-groupname FILESHARE
class-map match-all WEB
match access-groupname WEB
policy-map QOS
class VTC
  priority 256
class VOIP
  priority 128
class WEB
  bandwidth remaining percent 45
class MAIL
  bandwidth remaining percent 30
class FILESHARE
  bandwidth remaining percent 25
policy-map 2048
class class-default
  shape average 2048000
  service-policy QOS
policy-map 1024
class class-default
  shape average 1024000
  service-policy QOS
We were expecting to see 25% bandwidth reserved by default for routing traffic as per max-reserved-bandwidth default. However as we are shaping the default reserved for the class-default under the policy-map QOS is being ignored. My question is, how is the routing traffic guaranteed if the class-default became flooded with traffic? Is the only option available to create the class-default and allocate it a bandwidth within the policy-map QOS, or are there other options open. I have noted this appears to be the future solution when the max-reserved-bandwidth is fully deprecated under IOS 15. Any help would be greatly appreciated.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The QoS features were enhanced (significantly) with HQF (12.4.20T).  Define a class-default under your QoS policy and define its bandwidth.
Edison Ortiz
You can also explicitly define a class and policy for routing protocols and allocate bandwidth.
Routing protocols use CS6.
Thanks Edison,
     I can see that will work, however even without matching the CS6 traffic and allowing it to fall into class-default the CS6 traffic appears to get through when flooding with BE traffic through the class-default. Does the CS6 traffic still get treated with priority over BE traffic within the undefined class-default?
Disclaimer
Posting
Depends on whether class-default is using FIFO or FQ and whether FQ is just FQ or WFQ.  The latter, WFQ, will give IPPrec 6 (including CS6) packets a scheduling boost.  (NB: HQF uses FQ.  I think pre-HQF, undefined class-default uses WFQ.)
