Max Throughput ISR 4331 Booster Lic can handle
Lapta
Hello Folks,
From ISR 4K Series Data Sheet  ISR 4331 with boost license's throughput is over 2Gbps.
4431 boost lic throughput is over 4Gbps.
Well, 4331 should not able to hit 4Gbps, right? So what is "OVER 2Gbps" ?
I can not find in any other cisco documentation about the fix maximum limit for 4331 throughput.
How about 2.5Gbps aggregate traffic acrose all of the egress traffic? can 4331 handle it?
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
1.2Gbps
Joseph W. Doherty
A boost license removes the license performance cap, so you can obtain whatever performance the router can provide running at 100% CPU.  What can be achieved at full 100% CPU load very much depends on your configuration and your traffic.
I've attached an earlier Cisco whitepaper on pre-4K ISRs performance.  What to take note of, is how much CPU loading, and maximum throughput, varies, based on router config and traffic mix.  When you uncap/boost a 4K, you'll likely see similar relative results.
So, the "over 2Gbps" likely means simple forwarding of max MTU Ethernet frames.  (Take note of performance numbers in Table 1, where even a 1921 can have "over 2Gbps" throughput.)
You might also want to view https://miercom.com/pdf/reports/20150817.pdf stats on the 4331, page 12, and look at percent of CPU loading for various configurations.  I.e. @300 Mbps, lots of unused CPU capacity for just IPv4 forwarding, but CPU pretty much fully utilized for FW, NAT, QoS and IPSec.
If this is still unclear, let me know.
balaji.bandi
Max 1GB for that model  if you looking 2.5G then you need to uplift the model to 4461
BB
Joseph W. Doherty
You right Joseph. Thanks for help clearing this over throughput.
I found CPU load test with boost license. On aggregate CEF, 4331 can handle 2Gbps with 53% CPU and will increase along with configured feature like netflow, ipsec, etc.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/PSOCOL-2009.pdf
On Slide 42
Platform Factory Default Performance License Boost License
44511Gbps 2 Gbps @ 19% CPU 4 Gbps* @ 35% CPU
4431500Mbps 1 Gbps @ 18% CPU 4 Gbps* @ 62% CPU
4351200Mbps 400 Mbps @ 17% CPU 2 Gbps* @ 45% CPU
4331100Mbps 300 Mbps @ 16% CPU 2 Gbps* @ 53% CPU
432150Mbps 100 Mbps @ 8% CPU 2 Gbps* @ 68% CPU
422135Mbps 75 Mbps @ 8% CPU 1.4 Gbps @ 94% CPU
