maximum default static route?
woncheol.kim
Hi all!
How many default static routes can I configure?
currently, I use IOS 12.2 SRD4 version
Any help much appreciated.
Mahesh Gohil
Level 7
Level 7
You can put as many as you want but ultimately everything is depend on your router memory.
I mean to say where your config is stored like nvram.
however at a time you can have only six equal cost routes prefered. If your requirement is redundancy then you can use floating static routes with
different costs.
Mahesh
Mahesh Gohil
Level 7
Level 7
different costs.
Mahesh
