Maximum Path in BGP
gaurav.prakash
The requirement for 'maximum path' in BGP differs in MPLS network and non-MPLS network. The router wil put two+ routes using maximum path command even if their some attributes are diferent.
But in MPLS BGP network some attributes, such as LP , MED etc need to be same and with different next-hops , so that the router can choose two BGP routes using maximum path command.
Plz explain why this requirement in MPLS BGP network...?
Thx,
G
a-vazquez
Level 6
Level 6
BGP Multipath allows installation into the IP routing table of multiple BGP paths to the same destination. These paths are installed in the table together with the best path for load sharing. BGP Multipath does not affect bestpath selection.Refer URL
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml#bgpmpath
