maximum performance on router Cisco 7206VXR (NPE-G2)
hatman
hello,
am use router Cisco 7206VXR (NPE-G2) ram 1G now am enable bgp routing full route aboute 400K record , ospf routing
maximum traffic throughput is 400 Mbps but the cpu utilize is 80%
Could you tell me this is normal status or not??
Leo Laohoo
This about the right figure.  The entire NPE G2 blade (not per interface, mind you) can push about 1Gb of traffic (half duplex and no encryption).
What is mean 1 G and half dulplex ?
show process cpu sort - from my router.
CPU utilization for five seconds: 57%/56%; one minute: 62%; five minutes: 61%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   5    59435312     3079985      19297  0.31%  0.61%  0.62%   0 Check heaps
142       90864  1397439722          0  0.23%  0.18%  0.17%   0 HQF Shaper Backg
273       11384        1404       8108  0.23%  2.34%  1.07%   4 SSH Process
270   139390900    46654520       2987  0.15%  1.57%  1.91%   0 BGP Router
   2      170672     1173612        145  0.07%  0.02%  0.00%   0 Load Meter
117       64812    19337221          3  0.07%  0.02%  0.01%   0 TCP Timer
  87     7251740    42320499        171  0.07%  0.10%  0.09%   0 IP Input
112       21868     8128979          2  0.07%  0.00%  0.00%   0 CEF: IPv4 proces
110     5922320    17561471        337  0.07%  0.06%  0.07%   0 IP RIB Update
  10        1248       97675         12  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
