Maximum Routes
vishwancc
Level 3
Level 3
Could any one tell the maximum# of routes in the routing table on 6500 with sup WS-X6K-SUP1A-2GE.
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 49375K 16033K 16384K 9636K 6748K 512K 118K 394K
8 Replies 8
andrew.prince
Level 10
Level 10
None - as Multilayer (Layer 3) switching is Unsupported
See the below datasheet:-
http://www.cisco.com/en/US/products/hw/modules/ps4835/products_data_sheet09186a00800887fd.html
HTH>
Hi Andrew,
My bad i have added extra WS-F6K-MSFC2 on this sup with 128 ram .
Chao
Vishwa
128k route limitation.
HTH>
Hi Andrew,
Thats means it will only support 128000 routes in the routing table irrespective of they are static ,or dynamic (EIGRP,BGP,OSPF )
Chao
Vishwa
That is correct - so really this device should not be used as an interfacing BGP router, and recevie the whole internet routing table!
But for an internal device, this should be fine.
HTH>
Thanks Andrew.
Chao
Vishwa
np - glad to help
Hi Andrew,
do you have any document saying that it will support 128k route ,will be really helpful.
Chao
Vishwa
