Nail up Dialer2 failover interface
openipltd
Using 1841 with 2x HWIC-1ADSL-M, different ISP on each for resilience. Not attempting outbound load balancing at this point. Default route is out of Dialer0. The problem is that if the Dialer2 drops, the router never tries to bring it back up again [as far as I can tell]. Dialer0 continues to work, but we use Dialer2 for remote management, and also it would be nice if Dialer2 would stay up permanently as this would give us a chance to notice any issues with the Dialer2 circuit and fix them before it becomes critical. The router will bring up Dialer2 as part of the reload process, so it must be a config issue which is at fault.
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 0/38
oam-pvc manage
pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface ATM0/1/0.2 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface Dialer0
description $FW_OUTSIDE$
ip address 81.x.x.x x.x.x.x
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip inspect DEFAULT100 out
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxx
ppp chap password 7 XXXXX
crypto map SDM_CMAP_1
interface Dialer2
ip address 94.x.x.x x.x.x.x
ip access-group 110 in
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap pap callin
ppp chap password 7 xxxxx
ppp pap sent-username xxxxx password 7 xxxxx
openipltd
I set a static route out of Dialer2 for a host, then put an 'ip sla ...' on it, so I know there is always interesting traffic for Dialer2. I have also forwarded syslog to a server out of Dialer0. I can see that at one point the SLA target stopped responding, then the ATM0/1/0 DSL dropped, came back up, re-logged in and the SLA came back:
Mar 24 21:22:30.845 PCTime: %TRACKING-5-STATE: 50 ip sla 150 reachability Up->Down
Mar 24 21:23:01.749 PCTime: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 6001: Neighbor 172.28.77.2 (Tunnel2) is down: holding time expired
Mar 24 21:23:05.433 PCTime: %LINK-3-UPDOWN: Interface ATM0/1/0, changed state to down
Mar 24 21:23:06.397 PCTime: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
Mar 24 21:23:06.401 PCTime: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di2
Mar 24 21:23:06.433 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/1/0, changed state to down
Mar 24 21:23:07.397 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
Mar 24 21:23:15.437 PCTime: %LINK-3-UPDOWN: Interface ATM0/1/0, changed state to up
Mar 24 21:23:16.437 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/1/0, changed state to up
Mar 24 21:23:17.809 PCTime: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
Mar 24 21:23:17.809 PCTime: %DIALER-6-BIND: Interface Vi2 bound to profile Di2
Mar 24 21:23:20.965 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Mar 24 21:23:34.809 PCTime: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 6001: Neighbor 172.28.77.2 (Tunnel2) is up: new adjacency
Mar 24 21:24:25.845 PCTime: %TRACKING-5-STATE: 50 ip sla 150 reachability Down->Up
So all seems well there. But then at 01:08 the SLA stops responding:
Mar 25 01:08:27.352 PCTime: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 6001: Neighbor 172.28.77.2 (Tunnel2) is down: Interface Goodbye received
Mar 25 01:08:30.884 PCTime: %TRACKING-5-STATE: 50 ip sla 150 reachability Up->Down
Mar 25 01:08:31.956 PCTime: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 6001: Neighbor 172.28.77.2 (Tunnel2) is up: new adjacency
Mar 25 01:09:10.660 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
According to the ISPs RADIUS logs the router disconnected with a Port-Error terminate clause. And that's where it stands right now. ATM0/1/0 and Dialer2 both show as up/up, but Dialer2 is not logged in. A shut/no shut on ATM0/1/0 and Dialer2 will not get it to log back in.
What's odd is that if I clear the counters on ATM0/1/0 they never increment in either direction:
#show int atm0/1/0
ATM0/1/0 is up, line protocol is up
Hardware is HWIC-DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 448 Kbit/sec, DLY 1140 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 11:57:25, output hang never
Last clearing of "show interface" counters 00:44:45
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 477
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
With various PPP/ATM/PPPoATM debugging options on:
049788: *Mar 25 13:00:19.573 PCTime: Vi2 LCP: O CONFREQ [REQsent] id 219 len 10
049789: *Mar 25 13:00:19.573 PCTime: Vi2 LCP: MagicNumber 0x28183C20 (0x050628183C20)
049790: *Mar 25 13:00:21.589 PCTime: Vi2 LCP: Timeout: State REQsent
049791: *Mar 25 13:00:21.589 PCTime: Vi2 LCP: O CONFREQ [REQsent] id 220 len 10
049792: *Mar 25 13:00:21.589 PCTime: Vi2 LCP: MagicNumber 0x28183C20 (0x050628183C20)
049793: *Mar 25 13:00:23.605 PCTime: Vi2 LCP: Timeout: State REQsent
049794: *Mar 25 13:00:23.605 PCTime: Vi2 LCP: State is Listen
049798: *Mar 25 13:00:53.621 PCTime: Vi2 LCP: Timeout: State Listen
049799: *Mar 25 13:00:53.621 PCTime: Vi2 PPP: No remote authentication for call-out
049800: *Mar 25 13:00:53.621 PCTime: Vi2 LCP: O CONFREQ [Listen] id 221 len 10
049801: *Mar 25 13:00:53.621 PCTime: Vi2 LCP: MagicNumber 0x28190021 (0x050628190021)
049803: *Mar 25 13:00:55.637 PCTime: Vi2 LCP: Timeout: State REQsent
Seems like it never gets any LCP packets? Surely if the router is sending CONFREQs, the counters on ATM0/1/0 should be incrementing?
Any ideas anybody? Still not working even after replacing the HWIC.
