Maximum VIC2-4FXO Supported in 2911 Router
ositechintl
What is the maximum number of VIC2-4FXO card is supported in 2911.
Ramesh
Ramesh,
    The referred link, in section TABLE-5 is talking about specifications for network module which can hold one or two VIC cards. these VICs are daughter cards that install into the network modules. Cisco router 2911 can hold one IP Communications Voice/Fax Network Modules.
the attachment below shows that you can install 4 ( VIC2-4FXO )cards into your router. don't forget to use the cool tool from cisco DSP calculator to obtain your PVDM card capacity to use the 4 VICs.
Please rate if its helpful
ositechintl
The below link shows the VIC2-4FXO is installed in any of the 4 Slots but  maximum of only 2 cards to be installed, is that correct,
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/ip-communications-voice-fax-network-modules/product_data_sheet0900aecd801c595e.html
Please refer in the section Table 5. Specifications for IP Communications Voice/Fax Network Modules on the above link.
Ramesh
Ramesh,
