maybe dead 1811
markworsnop
I have used 1811 that I have been trying to get configured. I was able to put one of my WANS on Fa1 and configure it as DHCP. For the most part this works. The 2nd WAN I put on Fa0 and it would not work. I finally reconfigured fa0 to be the same as fa1 and moved the cable that I know works to the fa0 port. The config is identical. I rebooted and I cant even get the fa0 port to show the DHCP info, like the ip address etc. I moved the cable back to fa1 and the info comes up without a problem.
This same router seems to like working for a period of time, and then for no reason just stops routing. Without making any changes it just starts again
I am thinking now that there must be something really wrong with this box. I have reloaded the flash with the current bin file and also put in a new flash card. nothing has helped.
Is it dead?
Giuseppe Larosa
Hello Mark,
post your NAT configuration in an attachment file.
the router has probably problems with NAT from time to time I remember similar threads.
I mean some process likely NAT consumes all resources of some type on the device causing the out of service.
I wouldn't say it is dead. You say you have moved to a recent IOS image so now a look at configuration may help.
Hope to help
Giuseppe
