Meaning of Show Module Output - Outserv Status
balajitvk
Level 4
Level 4
My Show module showing different status for two of my SPAs... Can anybody suggest what is that mean????
Attached the show module and show version fyr.
Rgs
Balaji,
Has the 2nd SPA worked before?
I haven't personally worked with SPA much. But, just wondering whether the combination of SPA-200 and SPA-400 in the same chassis is causing this due to either oversubscription or incompatibility.
I don't know if you already looked at this SPA troubleshooting document. If you haven't go through the troubleshooting steps and see if you can nail the problem.
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a0080440317.html#wp1082304
In addition you may want to use feature navigator tool to check for hardware compatibility.
Sundar
Hi Sundar,
Thx for your response. But thrown some light on something else but useful...
Same configuration on other 7600 boxes is working fine. So i don't think it is due to incompatctibility or oversubscription....
I just do want to know what is Outserv Status on show module output which may give some idea on the same...
Rgs
