My router us 7206 vxr, customer needs DRAM upgradation, could you help me out taking out the current details viz how many slots are there for DRAM & the current memory is occupied by how many slots .
Pasting the sh ver output below , plz let me know if other outputs are required.......
pcmh008#sh version
IOS (tm) 7200 Software (C7200-IS-M), Version 12.3(10b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 21-Dec-04 17:08 by kellythw
Image text-base: 0x60008AF4, data-base: 0x61C78000
ROM: System Bootstrap, Version 12.1(20000824:081033) [dbeazley-cosmos_e_LATEST 101], DEVELOPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(13)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
pcmh008 uptime is 4 days, 5 hours, 10 minutes
System restarted at 13:42:45 UCT Sat Dec 30 2006
System image file is "disk0:c7200-is-mz.123-10b.bin"
cisco 7206VXR (NPE300) processor (revision D) with 122880K/40960K bytes of memory.
Processor board ID 23672205
R7000 CPU at 262MHz, Implementation 39, Rev 2.1, 256KB L2 Cache
6 slot VXR midplane, Version 2.3
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 290 bandwidth points. This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 200 bandwidth points. This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on CCO <www.cisco.com>, for c7200 bandwidth points oversubscription/usage guidelines.
2 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
47040K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Thnks /Anurag
