Memory problem on Cisco 1905 with NAT/PAT
csco10851302
Hi guys,
Good to talk to you again, my case is the follow:
I have a router 1905 with the follows characteristics:
Technology Package License Information for Module:'c1900' ...Cisco 1905/K9
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
data datak9 RightToUse datak9
Router uptime is 7 minutes
System returned to ROM by reload at 22:51:14 UTC Thu Apr 28 2016
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
But when i put the command "ip nat outside" in one of the interfaces i have the follow error:
Router(config-if)#ip nat outside
% NBAR Error: due to memory problem, parsing stopped
% NBAR Error: Activation failed due to insufficient Dynamic Memory
% NBAR Error: Stile could not add protocol node
%NAT: Error activating CNBAR on the interface GigabitEthernet0/1
Router(config-if)#
*Apr 28 23:37:35.655: %SYS-2-MALLOCFAIL: Memory allocation of 10260 bytes failed from 0x239171B0, alignment 0
Pool: Processor Free: 26764 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Exec", ipl= 0, pid= 29
-Traceback= 23A90B94z 256656A8z 23907438z 239075C8z 238F6938z 238F6A70z 238F6B14z 238F69C8z 238F6B14z 238F69C8z 238F6B14z 238F7D20z 23904C50z 23908CC4z 238E2ED4z 2392A0C8z
*Apr 28 23:37:35.655: %NBAR-2-NOMEMORY: No memory available for StILE lmalloc
-Traceback= 239075C8z 238F6938z 238F6A70z 238F6B14z 238F69C8z 238F6B14z 238F69C8z 238F6B14z 238F7D20z 23904C50z 23908CC4z 238E2ED4z 2392A0C8z 2392A448z 239688B8z 22F40BDCz
*Apr 28 23:37:43.251: %LICENSE-2-VLS_ERROR: 'VLSnotifyBirthAndExpiryEvents' failed with an error - rc = 25 - 'Error[25]: Could not understand the message received from license server on host "no-net".
Client-server version mismatch?
-Traceback= 23A7C2E8z 23A7C2CCz
Router#
after that, any command that i enter doesn´t show anything...just i reload the router....but the problem remains.
I will appreciate your help with some advices.
Golbert
csco10851302
I upgraded the ios router to the last release:
System returned to ROM by reload at 22:26:39 UTC Fri Apr 29 2016
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-4.M10.bin"
Cisco CISCO1905/K9 (revision 1.0) with 229376K/32768K bytes of memory.
Processor board ID FTX1728822Z
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
but the problem remains!!!!
any advice???
Golbert
hi
i dont know if you solve that problem
i think exist more solution but i found one
if you have a 1905 and
if you have memory less than 512k and
if your IOS is kind of this c1900-universalk9-mz.SPA.154-3.M3
TO SOLVE YOUR PROBLEM ...
you will need
to cisco configure you more memory in that router
or
you must to downgrade your IOS version
or
you must to prescinde to NAT ...because in the outside command the box is wrong ( i think use more memory of the cisco team think if needit)
Greetings from MEXICO gdl
