Memory
wynneit
I have three routers and a couple of simple questions.
I was hoping to have more memory but alas it appears I have 32Mb Ram with 16Mb of flash in my 2610XM and 24Mb Ram and 8Mb of flash in my 2610.
What is the best image I can put on these, I am thinking of putting the 2610XM memory in the 2610 and running 12.3 and upgrading the 2610XM to 128Mb DRAM and 32Mb Flash.
Also any issues running FR on a 2510?
cisco 2610XM (MPC860P) processor (revision 0x100) with 26624K/6144K bytes of mem
ory.
Processor board ID JAD0626CJ8S (2478210345)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
cisco 2610 (MPC860) processor (revision 0x202) with 18432K/6144K bytes of memory
Processor board ID JAB0314051K (599344332)
M860 processor: part number 0, mask 49
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
8192K bytes of processor board System flash (Read/Write)
Giuseppe Larosa
Hello Pete,
you can move the memory chips but only two slots are present on the C2600
see
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/cnfgnote/2600mem.htm
You should be able to use FR on the C2510
Hope to help
Giuseppe
