Meraki MS130-48P switches and Catalyst 3945 ISR
tclsg itsupport
Hi all,
Scenario:
  • I've got an Meraki MX84 Security Appliance that acts as the gateway.
  • MX84 is connected to a Catalyst 3850 switch that acts as the backbone.
  • Connected to the 3850 are five Meraki MS130-48P switches and a 3945 ISR.
  • 3945 ISR is configured to be a call manager and has DHCP enabled.
  • Two VLANS (5 - Voice and 10 - Data)
  • The desk phones get their IP from the 3945 ISR
  • Computers and hand held devices get their IPs from the Windows Server DHCP
  • Switches and router are all connected to Trunks ports on the 3850.
  • The MS130-48Ps replaced the Catalyst 2960 series.
Problem:
After changing the Catalyst 2960 switches with the MS130-48Ps, I started having problems with the desk phones. All but two phones in the offices are either showing 'Phone not registered' or Network not available'. I have included the the mac address of the 3945 to the allowed DHCP list on the DHCP Servers list on the Meraki.
On the Meraki dashboard, all the phones show that they are connected with the right IP Address. However, from the 3945 ISR, I do not see the list of the devices when I use show ip dhcp binding.
Any help is welcome to solve the issue I face of the devices showing 'Phone not registered' or Network not available'.
5 Replies 5
Richard Burts
Am I understanding correctly that the network was using 2960 switches and was working correctly? And that you replaced these switches with MS130-48P and now most phones are not working? It sure sounds like there is some issue on MS130-48P. Can you verify their configuration?
Are there any log messages on the 3850 or on the 3945 that might relate to this issue? Or messages on MS130-48P?
Are you sure that the 3850 and MS130-48P agree on vlan assignment, etc?
Rick
Yes the network was ok when it had the 2960 switches. ANd after changing them to the MEraki MS130-48P switches the phones are all off bar two.
The Management VLAN on the Meraki is VLAN 10. This was changed from VLAN 1 since when its on VLAN 1 the Meraki uses dynamic DHCP even though it is configured to use static IP Address.
Below is the config on the 3850.
BACKBONE-SW#sh config
version 15.2
no service pad
service password-encryption
service compress-config
hostname BACKBONE-SW
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5
username admin privilege 15 password 7
aaa new-model
aaa session-id common
switch 1 provision ws-c3850-24t
ip name-server 172.16.0.2
ip name-server 172.16.0.3
qos queue-softmax-multiplier 100
vtp mode transparent
spanning-tree mode mst
spanning-tree mst configuration
name OfficeHQ
revision 1
instance 1 vlan 1-30
spanning-tree mst 0-2 priority 16384
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
vlan 5
name VOICEVLAN
vlan 10
name DATAVLAN
vlan 15
class-map match-any non-client-nrt-class
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
description "SERVER ACCESS PORT"
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/20
description "UPLINK TO ACCESS SW"
switchport mode trunk
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface Vlan1
ip address dhcp
interface Vlan10
ip address 172.16.0.10 255.255.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
line con 0
password 7
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7
transport input telnet ssh
line vty 5 15
ntp server 172.16.0.1
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
Hello
do your ports require poe? and if so is the new meraki capable
Kind Regards
Paul
The Meraki MS130-48P switches are PoE capable and my APs are connected to them using PoE and so are the deskphones.
ammahend
on the MS130 make sure the STP root is correct, if not fix it.
-hope this helps-
