Mesh Convergence with WLC 5508 & 2504 with 1552S Access Points
I have two different setups with WLC 5508 and WLC 2504 with 8 1552S Access Points.
2 RAP(s) are connected to the switch & 6 MAP(s) are in 802.11a mesh (max 2 hops).
The WLC 5508 or WLC 2504 is running with 8.3.133.0 firmware.
Mesh Convergence is configured as "Very Fast".
I am observing that whenever I switch OFF one of the RAP(s) (especially the RAP with which all the MAP(s) have active links), during mesh convergence all the MAP(s) drop from the network (even though their inactive link with the other RAP has good SNR)& they re-join the network with active links with RAP2. I expect that the mesh convergence should be seamless & the MAP(s) should not drop when one of the RAP(s) is switched OFF.
Can anyone guide me to as what is going wrong? Is there any configuration that I have missed? Or is this an expected behavior.
0 Replies 0
