MHSRP: %Multi-redundancy entry not supported
teymur azimov
Hi. please help me. i configuration MHSRP at router cisco 2901.
Router-B(config)#ip nat Stateful id 1
Router-B(config-ipnat-snat)#redundancy SNAT1
Router(config-ipnat-snat-red)#mapping-id 1
Router(config-ipnat-snat-red)#redundancy SNAT2
...Router(config-ipnat-snat-red)#exit
when i write redundancy SNAT2 this error occur:
please write your comment.
See More
Giuseppe Larosa
Hello Teymur,
you are configuring stateful NAT SNAT in HSRP mode.
the feature provides a one to one corrispondence between an HSRP group/instance and SNAT instance, so you should use a different mapping-id for SNAT2 redundancy group.
otherwise if what you want is to have two set of stateful NAT rules associated to a single HSRP group you should merge the NAT rules.
if you want to split the NAT rules and to associate them to two different HSRP groups, each group should use a different redundancy name and a different mapping id
see
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_scale_stnat_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1052210
and
command reference
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1012991
for ip nat stateful id
Hope to help
Giuseppe
Did you ever find a solution for this ? I have the same issue ...
The problem is not the repeating mapping-id because the error happens before that command is entered, when you try to put a second redundancy.
And trying to configure a second snat group
ip nat Stateful id 2
doesn't work for me either:
% SNAT with id : 1 already running. Please remove and reconfigure%
