Can anyone tell me what is the mib id for "bandwidth receive" on routers.
i know whati it is just for the bandwidth but i can't find it for the bandwidth receive.
Thank you.
Genrally for bandwidth monitoring for interface certain formula used to work with mib vlaues check out the below link hope this helps out your query !!
If helpful do rate the valaubel post.
