Mid-range router
ahmedalnajjar
Is the 2851 router meet these requirments ? if no.
What is the must specific series of the routers suitable for this requirments:
1. Comprehensive interface range supporting T1/E1, NxT1/E1, FE, and  High-Speed WAN
2. Wide array of Layer 2 access protocols including Frame Relay, Ethernet,  and PPP/HDLC
3. Rich and granular QoS and instrumentation for prioritizing mission-critical traffic such as voice
4. A modular platform with a broad range of interface options.
5. Network Address Translation (NAT), and IPSec
6. Four (4) auto sensing LAN Ports (10/100/1000) Mbps built-in routed ports.
7. WAN Interface Slots (4-6 option Slots)
8. WAN Interface Modules (2xT1/2xE1/2xSerial/2xFE/DS3)
9. Memory (512/1024 MB DRAM)
10. Built in redundancy (Power Supply)
11. Two (2) Integrated GE ports with copper and fiber support
12. Support for a Small form-Factor Pluggable ( SFP) port for GE.
13. Support Network Timing Protocol (NTP)
14. Security
  • On-board encryption
  • Support of up to 2500 VPN tunnels with the AIM-HPII-PLUS Module
  • Antivirus defense support through Network Admission Control (NAC)
  • many more essential security features
15. Voice
  • Optional support for Survivable Remote Site Telephony support for local call processing in small enterprise branch offices for up to 240 IP phones.
16. Performance
  • Up to 1GB DRAM
  • Up to 1GB Flash
  • The maximum transmission unit (MTU) Up to 9576 bytes
  • Throughput up to 1.2 Gbit/s
17. 110/220 volts.
18. Warranty certified by Sis 98 or by OEM (original equipment manufacturer)
19. Up to 115.2 Kbps for Console/Aux port with DDR capability.
20. Supports IPv6
ahmedalnajjar
any update
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Sorry no.
Ahmed, questions on these forums are answered voluntarily.  What you're requesting is the kind of information that might be found in a response to a RFP.  It's doubtful anyone will spend hours of research that might be needed to answer all your questions.  Much of the information you're asking can be found on production datasheets and/or related Q and A sheets.  You might start here: http://www.cisco.com/en/US/products/ps5854/index.html
If you have specific questions, such as perhaps explaining some feature, that's likely to be answered.
Also, BTW, believe the 2800 series is EOL so if you're looking to acquire a new ISR, might want to look at the "replacement" 2900 series.
