MIGRATE FRAME-RELAY TO MPLS
Luis Salazar
Hi, I Realy need help here please. I have already the configuration for the router. This router is configure with FR and it´s an operative network. I have to change the actual configuration to MPLS.
This is what i have for now:
class-map match-any MARCAJE_REAL-TIME
match access-group name ACL-REAL-TIME
class-map match-any MARCAJE_GESTION
match access-group name ACL-GESTION
class-map match-any MARCAJE_PLATINO
match access-group name ACL-PLATINO
class-map match-any MARCAJE_PLATA
match access-group name ACL-PLATA
class-map match-any MARCAJE_VIDEO
match access-group name ACL-VIDEO
class-map match-any MARCAJE_ORO
match access-group name ACL-ORO
class-map match-any REAL-TIME
match ip precedence 5
class-map match-any GESTION-ROUTING
match ip precedence 6  7
class-map match-any PLATINO
match ip precedence 3
class-map match-any PLATA
match ip precedence 1
class-map match-any VIDEO
match ip precedence 4
class-map match-any ORO
match ip precedence 2
!policy-map MARCAJE_ENTRADA
class MARCAJE_REAL-TIME
  set ip precedence 5
class MARCAJE_VIDEO
  set ip precedence 4
class MARCAJE_PLATINO
  set ip precedence 3
class MARCAJE_ORO
  set ip precedence 2
class MARCAJE_PLATA
  set ip precedence 6
class MARCAJE_GESTION
  set ip precedence 6
class class-default
  set ip precedence 0
policy-map LLQ-QoS-MAP
class REAL-TIME
  priority percent 25
  police cir percent 25
  conform-action transmit
  exceed-action drop
  class VIDEO
   bandwith 512
  class PLATINO
   bandwith 1536
class GESTION-ROUTING
  bandwidth 20
  class class-default
   fair-queue
interface Multilink2
bandwidth 3072
ip address 10.10.254.1 255.255.255.252
load-interval 30
ppp multilink
ppp multilink-group 2
interface FastEthernet0/1
ip address 192.168.3.4 255.255.255.0
load-interval 30
duplex auto
service-policy input MARCAJE_ENTRADA
interface Serial0/3/0
no ip address
encapsulation hdlc
ip route-cache flow
load-interval 30
interface Serial0/2/0
no ip address
   ip route-cache flow
load-interval 30
interface Serial0/1/0
no ip address
ip route-cache flow
load-interval 30
interface Virtual-Template1
mtu 1450
ip unnumbered Serial0/3/0.16
peer default ip address pool default
ppp authentication pap chap
router eigrp 100
network 192.168.0.0
auto-summary
map−class frame−relay mapclassVPN_BANES
no frame−relay adaptive−shaping
frame−relay cir 1024000
frame−relay bc 10240
frame−relay be 0
service-policy output LLQ-QoS-MAP
ip access-list extended ACL-GESTION
permit tcp any any range 22 telnet
permit tcp any any eq telnet
ip access-list extended ACL-VIDEO
permit ip host 192.168.3.40 192.168.1.5 0.0.0.240
ip access-list extended ACL-PLATINO
permit tcp 192.168.3.0 0.0.0.255 192.168.9.50 0.0.0.255 eq 512
permit tcp 192.168.3.0 0.0.0.255 192.168.8.0 0.0.0.255 eq ANY
I don´t now how to configure the interface serial, bacause this is the actual config with FR and i don´t now how to configure with MPLS.
no ip address
encapsulation frame-relay IETF
ip route-cache flow
load-interval 30
frame-relay traffic-shaping
frame-relay lmi-type cisco
interface Serial0/3/0.19 point-to-point
description Conexion con remote1
ip address 10.10.8.2 255.255.255.248
frame-relay interface-dlci 19 CISCO
  class enlace256
frame-relay ip rtp header-compression
interface Serial0/3/0.30 point-to-point
description Conexion con remote2
ip address 10.10.1.3 255.255.255.248
frame-relay interface-dlci 30 CISCO
  class enlace256
interface Serial0/3/0.31 point-to-point
description conexion con remote3
ip address 10.10.21.1 255.255.255.252
frame-relay interface-dlci 31 CISCO
  class enlace320
I have 3 links or V.35 conections. 1 with 1024kbps, other with 2048kbps. I have to conect 3 sucursal remotes with this two V.35 links. I attach a diagram of the network.
Please i really need your help, and i will be gratefull with any comments.
Luis C
paolo bevilacqua
Your SP must give you all the details, encapsulation, addressing, routing, QoS, etc.
