Migrating firewalls - routing issue
willb1
We are in the process of migrating from an older ASA to an FTD appliance. I've had the FTD in place for our site-to-site VPN's and am now at the point where I need to migrate servers which are behind the ASA over to the FTD.
We have an externally routable subnet which we refer to as the DMZ. It's not a true DMZ per say as it is located behind the outside interface.
Attached is a diagram.
  • I connected the "DMZ" interface on the FTD to an unmanaged switch, which is connected to the DMZ interface on the ASA. Our DMZ servers are also connected to the switch.
  • The outside interface of the new FTD is at 72.72.72.50/28 and the DMZ interface is on a different subnet at 72.72.72.46/28
  • The outside interface of the ASA is 72.72.72.52/28 and the DMZ interface is on the same subnet above at 72.72.72.33
  • The two firewalls are connected to an "outside" router with the original ip route set to ip route 72.72.72.32 255.255.255.240 72.72.72.52
  • I added separate IP route statements for the 4 servers we have in that subnet and deleted the statement above. 3 of the statements route traffic to the old ASA and the statement ip route 72.72.72.44 255.255.255.255 72.72.72.50 routes traffic to the new firewall.
  • I also updated the default route on the server to point to the DMZ interface of the new FPR (72.72.72.46).
  • I am neither able to access or ping the server from the internet nor from the outside router.
  • I am able to ping the server from inside the network.
  • From the server I can ping the FPR and IP's on the internet (8.8.8.8)
  • I have policies in place to allow ICMP and traffic to port 443 but I see no traffic in the connection logs bound from the outside.
  • I don't see any external traffic to the server when I perform a packet capture on the FTD. I do see other traffic.
I hope this answers most questions. I feel like I'm overlooking something stupid.
 If you can ping from the server to the internet but can not ping the server from the router, I only can think about firewall rule.
 Seems everything is in place about the network side. Can only imagine rules missing
 I looked I believe all the information and all seems right to me.
If you change the route  ip route 72.72.72.44 255.255.255.255 72.72.72.52 does the router can ping?
Yes, when I switch the routes and gateway back, I can ping. I am going to test further during a maintenance window over the weekend.
willb1
The NAT configuration had 'any' defined for the source interface instead of just 'inside'. Once I corrected that, the issue was resolved.
Good to know.
Honestly in any moment I thought NAT was in place. Always considered  routing only
