PORT FORWARDING RANGE
rotem.shein
Dear Techs,
i am trying to forward ports range of 10,000 to 20,000 for a customer PBX. normally i would use 1:1 NAT but he is requesting for specific traffic ports.
example:
public int: 192.168.1.3
internal IP: 10.0.1.49
My running config for NAT:
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
7 Replies 7
fb_webuser
Level 6
Level 6
try using a pool with the rotary command like this:
ip nat pool portforward 10.0.1.49 10.0.1.49 netmask 255.255.255.0 type rotary
ip nat inside source list 110 interface FastEthernet0/0.6 overload
ip nat inside destination list 100 pool portforward
access-list 100 permit udp any any range 10000 20000
access-list 110 permit ip 10.0.1.0 0.0.0.255 any
You have the normal overload, and the range in a pool to connecto to the pbx.
hope it helps
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
thanks very much for the prompt response....i have tried the commands i am still block on the NAT TRANS
when switching back to 1:1 NAT i am in again fine.
hope you can assist
thanks
fb_webuser
Level 6
Level 6
There is a another solution, using route-maps as well:
ip access-list extended UDP_RTP
permit udp host <SIP HOST> any range 16384 37248
route-map SIP_NAT permit 10
match ip address UDP_RTP
ip nat inside source static 10.1.1.1 20.20.20.20 route-map SIP_NAT
http://www.voip-blog.co.uk/index.php/2009/11/21/nat-sip-range-on-uc500-cme
In this access list, do we allow the private host ip address or the public ip address(from where the inbound traffic comes over to the LAN)?
Neeraj Arora
Level 3
Level 3
there is no clean solution for what you are trying to achieve except for using a one to one Static NAT mapping which you've already mentioned that it works.
there is no "range" command in NAT. so you would not be able to use Static NAT port translation as you'd have to configure 10,000 NAT statements.
So either use 1:1 NAT mapping or you can consider Pedro's suggestion of using route-map and matching ACL to only allow NAT to happen when these 10,000 ports are being accessed
For a similar query, check this thread:
https://supportforums.cisco.com/thread/2141607
Hope it helps
Neeraj
Hi Neeraj,
Referring to pedro's solution,
Wizard4777
your local pbx ip
