Migrating from IOS to IOS-XE
vthbox
I have configured zone based firewall & nat overload on C1121 IOS-XE router. Internet stops working when I apply access-list to restrict inbound traffic on WAN interface. It's mandatory to restrict access from outside on WAN interface. Appreciate any help.
config :
interface GigabitEthernet1
ip address 1.1.1.1 255.255.255.0
ip nat inside
zone-member security IN
negotiation auto
no mop enabled
no mop sysid
end
CSR#sh run int Gi2
Building configuration...
Current configuration : 198 bytes
interface GigabitEthernet2
ip address 150.1.1.1 255.255.255.0
ip nat outside
ip access-group OUTSIDE-TO-INSIDE in
zone-member security OUT
negotiation auto
no mop enabled
no mop sysid
end
class-map type inspect match-all IN-OUT-CLASS
match access-group name IN-OUT-ACL
class-map type inspect match-any WEB-CLASS
match protocol http
policy-map type inspect WEB-POLICY
class type inspect WEB-CLASS
inspect
class class-default
policy-map type inspect IN-OUT-POLICY
class type inspect IN-OUT-CLASS
inspect
class class-default
zone-pair security IN-OUT-ZP source IN destination OUT
service-policy type inspect IN-OUT-POLICY
zone-pair security OUT-IN-ZP source OUT destination IN
service-policy type inspect WEB-POLICY
ip access-list extended OUTSIDE-TO-INSIDE
permit tcp any host 150.1.1.1 eq 443
permit udp any host 150.1.1.1 eq isakmp
permit udp any host 150.1.1.1 eq non500-isakmp
permit esp any host 150.1.1.1
ip access-list extended nating
permit ip 1.1.1.0 0.0.0.255 any
ip nat inside source route-map NAT interface GigabitEthernet2 overload
route-map NAT permit 5
match ip address nating
Cisco IOS/IOS-XE에서 Logging 설정 하기 NAT with VRF - IOS vs IOS-XE bad cli error - Cannot push service interface template on C1121-4P Cisco 3850: IOS-XE/Firmware Upgrade @Cisco Support Team
balaji.bandi
what was the IOS Code this was working, what is new IOS XE version you upgraded to ?
BB
Hi Balaji, thanks a lot for responding. We have this configuration working
on "c800-universalk9-mz.SPA.155-3.M4a.bin". Planning to upgrade this router
to C1121 with IOS-XE 17.02.02.
Kureli Sankar
Pls. do not combine ZBF with ACL.  Remove the ACL and let ZBF do its job.
-Kureli
Thank you Kureli, If I remove the ACL "OUTSIDE-TO-INSIDE" on WAN interface then how to restrict inbound packets without disturbing internet. I think ACL is blocking stateful inspection by ZBF which should not happen. Thanks a lot in advance.
