Migration from EIGRP to OSPF
paulmoesher
I am tasked with migrating a network from EIGRP to OSPF. My thought is that I would start configuring OSPF on the exterior and work my way to the core. That being said my end goal is that the core be the designated router. I am worried that if I start enabling OSPF on the exterior first then another router would become the designated router before I get to the core, even if I configure the core with a higher OSPF priority due to the fact that an OSPF DR has already been elected. I know that once I get to the core I can start shutting interfaces and restarting the OSPF process to force the core to be the DR but I really do not want to go that route.
My current idea is that I figure all exterior routers with an OSPF priority of 0 then once I get to the core configure that with an OSPF priority of 2 then the routes will be learned and the core will be the designated router.
My only worry is that if I set all of the exterior routers with a priority of 0 will they still form neighbor relationships with each other and then cause redundant traffic to be passed around the network until I configure the core due to the fact that there is no designated router?
Additionally, if I go this way then there will never be a backup designated router. How important is it to actually have one of your routers be elected as BDR in OSPF?
16 Replies 16
Understood, thank you for clarifying that.
Yunus Emre DEV
hi,
In fact, you can easily run such service and routing protocols using VRF.
your build is not very big as far as i understand.
moreover you have only one core router.
