IP SLA not show up under Track Object Command
hfakoor222
Trying to get HSRP to switch routers upon connection failure
Router Edge1 & Edge2 conenction to INSIDE
I've created IP SLA tracked object for connection
however there is no ip sla option
I've looked at 2 guides for object tracking and they've shown examples where it exists
I am using IOSvl2 15.2
would someone be able to indicate why it doesn't exist or a potential work around
5 Replies 5
balaji.bandi
not sure what image is this. IOL 15.X  I see the command : (post-show version)
BB
Its a router
with
(C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14
hfakoor222
 i looked up online that some older routers do not support IP SLA ~
In this case does any one ave a recommendation and guide me towards a work around which I could use?
I imagine myself being employed in the field and coming up to a situation where I cant track SLA, so I would like to habve a work around on hand
You are running an older version of code so try "track 1 rtr ..."
Jon
then that is not IOL, that is router dynamips
(C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Router(config)#track 1 ?
application Application
interface Select an interface to track
ip IP protocol
list Group objects in a list
rtr Response Time Reporter (RTR) entry
stub-object Stub tracking object
Router(config)#track 1 rtr ?
<1-2147483647> Entry number
BB
